Samsung Washing Machine Dispenser Drawer Removal
Views: 1.2K
View statistics:
Past 24 Hours:
10
Past 7 Days:
95
Past 30 Days:
356
All Time:
1,166
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Video Guide This guide was transcribed from a YouTube video.
Introduction
Go to step 1 ↓
Use this guide to remove, clean, and refit the dispenser drawer on a Samsung washing machine. The dispenser drawer, detergent drawer, or soap drawer holds detergent and fabric conditioner, and it can build up residue, residue, and mold over time. Cleaning it periodically helps keep the machine hygienic and helps prevent residue from washing onto clothes. This guide was written for a Samsung Ecobubble washing machine, and other Samsung models may have minor differences.
Tools
      • Turn off and unplug the washing machine before removing or cleaning the dispenser drawer.
      • Keep water away from the control panel, power cord, and plug while cleaning.
      • Use a brush kept only for cleaning, not one that will be used for brushing teeth.
      Ask FixBot
      • Find the dispenser drawer at the top left of the washing machine front panel.
      • Place a hand under the drawer handle and pull the drawer straight out until it stops.
      • Don't force the drawer past the stop, because it is still locked in place.
      Ask FixBot
      • Look inside the opened drawer for the blue release button near the rear of the drawer.
      • Press the blue release button down.
      • Keep the button pressed and pull the drawer straight out of the washing machine.
      Ask FixBot
      • Check the dispenser drawer for detergent residue, conditioner residue, residue, gunge, and mold.
      • Lift out the blue cover if residue is trapped underneath it.
      • Use a brush with hot, soapy water to scrub the removed drawer and blue cover.
      • Clean until the compartments are clear of buildup.
      Ask FixBot
      • Inspect the dispenser drawer cavity inside the washing machine before refitting the drawer.
      • Use a cleaning cloth with hot, soapy water to wipe inside the cavity.
      • Do not use a brush inside the cavity, because dropping it down the hole can lose it inside the machine and damage the washer.
      Ask FixBot
      • Line up the dispenser drawer with the grooves in the drawer opening.
      • Slide the drawer straight in until it seats fully.
      • Press the blue release button down again if the drawer catches while sliding in.
      Ask FixBot
      • Open the door and check the rubber seal inside the drum for mold, residue, and debris.
      • Use a cleaning cloth to wipe the rubber seal clean.
      • Make sure the drainage holes in the seal are clear.
      Ask FixBot
      • Plug the washing machine back in when all cleaning is complete and the area is dry.
      • Make sure there are no clothes in the drum.
      • Run the hottest available wash program, such as a 90 °C Cotton cycle or the Drum Clean option.
      • This hot empty wash flushes loosened residue from the machine before the next laundry load.
      Ask FixBot
The dispenser drawer should now slide in and out smoothly, and the drawer area should be cleaner for future washes. Repeat this cleaning periodically to reduce detergent residue, conditioner buildup, mold, and laundry odors. Repair didn't go as planned? Ask our Answers community for help.
eCuration
478,744 Reputation
396 Guides authored
0 Guide Comments
Past 24 Hours: 10
Past 7 Days: 95
Past 30 Days: 356
All Time: 1,166
