Shop the Holiday Gift Guide
Samsung WB850F Screen Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
24
Past 30 Days:
92
All Time:
1,612
Comments: 2
2 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will give user step by step instructions on how to replace the screen of the camera.
Parts
Tools
    1. Samsung WB850F Screen Replacement, Screen: step 1, image 1 of 3 Samsung WB850F Screen Replacement, Screen: step 1, image 2 of 3 Samsung WB850F Screen Replacement, Screen: step 1, image 3 of 3
      • First remove the battery and SD Card
      • Then use the screwdriver to remove the 6 screws that need to be removed to take off the outer case.
      • 2 screws are located on the bottom.
      • 2 screws are located on the left side (near the HDMI port).
      • 2 screws are located on the right side (opposite side of the HDMI port).
      Ask FixBot
    2. Samsung WB850F Screen Replacement: step 2, image 1 of 1
      • Once the screws are removed, use the blue opening tool to open the back case from the sides - it should come off easily.
      Ask FixBot
    3. Samsung WB850F Screen Replacement: step 3, image 1 of 2 Samsung WB850F Screen Replacement: step 3, image 2 of 2
      • Use the screwdriver to remove the small silver screw holding down the control panel (located on the bottom right next to the screen).
      • Use the blue opening tool to lift up the control panel from where the screw was just removed.
      Ask FixBot
    4. Samsung WB850F Screen Replacement: step 4, image 1 of 1
      Tool used on this step:
      Buy
      • Use the tweezers to gently pull the yellow control board ribbon cable out of its connector.
      • The display cable stands straight up and pops out easily. Pull up on it to remove the screen from the camera.
      Ask FixBot
    5. Samsung WB850F Screen Replacement: step 5, image 1 of 1
      • Connect the new screen by gently pressing the display cable on to its connector (on the motherboard).
      • When reinserting the control board, make sure the top of the control board is under the lip before screwing it in place.
      Ask FixBot
2 other people completed this guide.
Author
with
Jousling Vazquez
431 Reputation
4 Guides authored
USF Tampa, Team 12-4, Eyestone Spring 2016 Member of USF Tampa, Team 12-4, Eyestone Spring 2016
USFT-EYESTONE-S16S12G4
4 Members
48 Guides authored
2 Guide Comments
I previously mentioned that I had a sticky substance seeping from my camera. I spent quite a long time, using acetone to remove this fluid stuff from the LCD and the clear screen which was stuck to the LCD. It was not an easy task because of the quick evaporation of the acetone. Now, must I stick the LCD and the part/clear lens together? If so, with what glue? The second part to my question is that there was a second plate (?) with a rubbery surface on one side and I did not notice which side faces the lens because it fell out before I noticed it, rubber or plain metal? Any help will be appreciated. :-(
Ian Blyth - Reply Share
Is it normal from such a renowned company? I even got some instability in installed programs.
Hon Fah Cheung - Reply Share
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 92
All Time: 1,612
