Introduction
This guide will show you how to replace the battery in your Samsung WB350F in two easy steps.
The first step in replacing the battery is to locate battery compartment. This compartment can be found on the underside of camera.
To open this compartment, slide the latch to the left.
Depress the battery's retaining clip and remove the old battery.
Replace the old battery with a new battery.
My battery will not come out. I can push down on it but it doesn't move. The blue clip holding battery moves but battery is stuck in place.
I’ve got this same problem. Does anyone have a solution please? Short of destroying the camera to get the battery out, I’m stuck!
One Comment
Does anyone know where to get the battery terminal slide piece. My-Ex wife broke it so that when you slide the part which I don't even know how to do this on purpose!! (at least no without breaking the casing)
