Samsung WB1100F LCD Screen Replacement
    1. Samsung WB1100F LCD Screen Replacement, LCD Screen Cover: step 1, image 1 of 2 Samsung WB1100F LCD Screen Replacement, LCD Screen Cover: step 1, image 2 of 2
      • Remove six 1.2 mm Phillips #00 screws connected to the tripod dock and adjacent screws.
      • Remove six 1.2 mm Phillips #00 screws from the side of the camera.
      Ask FixBot
    2. Samsung WB1100F LCD Screen Replacement: step 2, image 1 of 2 Samsung WB1100F LCD Screen Replacement: step 2, image 2 of 2
      • Use a plastic opening tool or spudger if available.
      • Using the flat end of a spudger, loosen the connection between the back panel and the device. Remove the back panel using your hands.
      Ask FixBot
    1. Samsung WB1100F LCD Screen Replacement, LCD Screen: step 3, image 1 of 2 Samsung WB1100F LCD Screen Replacement, LCD Screen: step 3, image 2 of 2
      • Remove four 1.2 mm Phillips #1 screws connected to the LCD screen.
      Ask FixBot
    2. Samsung WB1100F LCD Screen Replacement: step 4, image 1 of 3 Samsung WB1100F LCD Screen Replacement: step 4, image 2 of 3 Samsung WB1100F LCD Screen Replacement: step 4, image 3 of 3
      Tool used on this step:
      Buy
      • Flip the LCD screen over to reveal the display cable.
      • Use the tip of a spudger or your fingernail to flip up the small retaining flap on the display cable ZIF connector.
      • Be sure you are prying up on the hinged retaining flap, not the connector itself.
      • Using a pair of tweezers, remove the ribbon cable from its socket on the motherboard.
      • The white line on this ribbon cable marks the edge of the connection area. To reinstall, insert the cable into the connector up to this line, and then close the retaining flap. If the cable doesn’t insert easily up to (or very near to) this line, it’s probably misaligned and needs to be gently removed and repositioned.
      Ask FixBot
Jesse Lindsey
581 Reputation
5 Guides authored
Metro State, Team 1-1, Carpenter SU 2016 Member of Metro State, Team 1-1, Carpenter SU 2016
MSU-CARPENTER-SU16S1G1
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 111
All Time: 954
