Samsung WB1100F Camera Flash Replacement
    1. Samsung WB1100F Camera Flash Replacement, LCD Screen Cover: step 1, image 1 of 2 Samsung WB1100F Camera Flash Replacement, LCD Screen Cover: step 1, image 2 of 2
      • Remove six 1.2 mm Phillips #00 screws connected to the tripod dock and adjacent screws.
      • Remove six 1.2 mm Phillips #00 screws from the side of the camera.
      Ask FixBot
    2. Samsung WB1100F Camera Flash Replacement: step 2, image 1 of 2 Samsung WB1100F Camera Flash Replacement: step 2, image 2 of 2
      • Use a plastic opening tool or spudger if available.
      • Using the flat end of a spudger, loosen the connection between the back panel and the device. Remove the back panel using your hands.
      Ask FixBot
    1. Samsung WB1100F Camera Flash Replacement, Camera Flash: step 3, image 1 of 3 Samsung WB1100F Camera Flash Replacement, Camera Flash: step 3, image 2 of 3 Samsung WB1100F Camera Flash Replacement, Camera Flash: step 3, image 3 of 3
      • Remove four 1.2 mm Phillips #00 screws from the top panel.
      Ask FixBot
    2. Samsung WB1100F Camera Flash Replacement: step 4, image 1 of 1
      • Using the flat end of a spudger, loosen the connection between the top panel and the device. Remove the top panel using your hands.
      Ask FixBot
    3. Samsung WB1100F Camera Flash Replacement: step 5, image 1 of 1
      • Remove four 1.2 mm Phillips #00 screws from the flash assembly
      Ask FixBot
    4. Samsung WB1100F Camera Flash Replacement: step 6, image 1 of 1
      • Using your hands, remove the flash assembly. This should not require much force.
      Ask FixBot
    5. Samsung WB1100F Camera Flash Replacement: step 7, image 1 of 2 Samsung WB1100F Camera Flash Replacement: step 7, image 2 of 2
      • Using your hands, remove the top flash panel by pressuring down on the back to release a locking tab.
      Ask FixBot
    6. Samsung WB1100F Camera Flash Replacement: step 8, image 1 of 1
      • Desolder three wires on the flash assembly.
      Ask FixBot
    7. Samsung WB1100F Camera Flash Replacement: step 9, image 1 of 1
      • Gently remove the flash assembly from the body.
      Ask FixBot
Jesse Lindsey
581 Reputation
5 Guides authored
Metro State, Team 1-1, Carpenter SU 2016 Member of Metro State, Team 1-1, Carpenter SU 2016
MSU-CARPENTER-SU16S1G1
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 99
All Time: 1,059
