Samsung SyncMaster 2443 Backlight Inverter Replacement
  1. Samsung SyncMaster 2443 Backlight Inverter Replacement, Open the display: step 1, image 1 of 3 Samsung SyncMaster 2443 Backlight Inverter Replacement, Open the display: step 1, image 2 of 3 Samsung SyncMaster 2443 Backlight Inverter Replacement, Open the display: step 1, image 3 of 3
    • Remove the power cord.
    • Remove the display stand by removing the two screws on the round plate on the backside of the monitor
    • Open up the backside of the display (display placed face down on cloth to avoid scratches) by carefully releasing the snapped in latches using a screwdriver or opener tool.
  2. Samsung SyncMaster 2443 Backlight Inverter Replacement, Remove metal cage containing PCBs: step 2, image 1 of 2 Samsung SyncMaster 2443 Backlight Inverter Replacement, Remove metal cage containing PCBs: step 2, image 2 of 2
    • The metal cage housing the PCBs as just stuck to the backside of the LCD.
    • Carefully remove adhesive strips, release the cables to LCD and front panel buttons.
    • Remove SMPS PCB (switching mode power supply) by removing screws around.
  3. Samsung SyncMaster 2443 Backlight Inverter Replacement: step 3, image 1 of 3 Samsung SyncMaster 2443 Backlight Inverter Replacement: step 3, image 2 of 3 Samsung SyncMaster 2443 Backlight Inverter Replacement: step 3, image 3 of 3
    • Caution: Touching the capacitor wires may cause serious injury. Use a capacitor discharge probe to safely rid the capacitors of dangerous charges.
    • From power board desolder transformer. It has 6 pins on one and 4 pins on the other side.
    • Replace with new transformer. (Model TM-09176)
Thomas Widmaier
2,039 Reputation
10 Guides authored
Master Techs Member of Master Techs
Community
322 Members
2,539 Guides authored
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 48
All Time: 12,979
