Introduction
This guide will show you how to detach and replace the phone's touchscreen display.
Using your fingers, pry along the groove at the top of the phone.
Pull back on the rear casing until it comes free from the device.
The casing will make a cracking sound as it is removed.
Locate the red and white sim card located above the battery housing.
Remove the sim card by sliding it downwards from its slot with your fingers.
Insert a plastic opening tool into any side of the phone case to separate the keyboard from the rear panel.
Pry the keyboard away from the casing with the plastic opening tool.
Carefully peel the blue tape from the bottom of the flex cable and set it aside.
Use one of the plastic opening tools to loosen the flex cable from its central housing.
Pull lightly on the flex cable to free it from the housing.
The cable may audibly snap as it is freed from its attachment.
Picture shows a small black snap cover. This comes straight up. I then tried to pry up the cable. That doesn't happen. It slides out to the left in the picture.
Locate the clamp holding the gold display cable to the back of the screen.
Using the plastic opener tool, lightly pry the cable attachment into an upright position.
Once completed, the attachment should resemble the marked section.
I got to this stage. Disconnected just fine. Then saw step 23 and realized this was too far. I should have stopped before Step 21. I bought a used phone with a good display, so I'm happy with the frame it is in. On my current phone, the display has gone bad - weird colors, then nothing. I'm happy just replacing the screen with case. I don't need to snap it out of the casing as in Step 23. However, now that I've unplugged this gold display cable, it's a booger bear to plug back in, but I'll get it.
I bought the used phone for $10. I was hoping I could just put my SIM card in and go. There were no guarantees, nor would I expect one for $10. Battery was not good. When I put in a known good battery, the phone worked but battery would not charge on this phone. But the display is great. So I chose to switch out the display.
I could have stopped at Step 16 for my purposes. I did when dis-mantling my defunct screen phone.
13 other people completed this guide.
One Comment
Overall this was a great presentation. Very thorough and detailed, yet simple, with great pictures. Thank you.
