Samsung Series 5 UltraTouch Battery Replacement
  1. Samsung Series 5 UltraTouch Battery Replacement, Remove the Screws on the Back Cover: step 1, image 1 of 2 Samsung Series 5 UltraTouch Battery Replacement, Remove the Screws on the Back Cover: step 1, image 2 of 2
    • Power off the device. Remove the remaining screws holding the back cover in place:
    • Six 4.0 mm Phillips #00 screws.
    • Seven 6.7 mm Phillips #00 screws.
  2. Samsung Series 5 UltraTouch Battery Replacement, Remove the Rubber Pads: step 2, image 1 of 2 Samsung Series 5 UltraTouch Battery Replacement, Remove the Rubber Pads: step 2, image 2 of 2
    • Remove the two rubber pads concealing the final bottom case screws.
    • Remove the two 4 mm Phillips #00 screws found under these pads.
  3. Samsung Series 5 UltraTouch Battery Replacement, Remove the Back Cover: step 3, image 1 of 2 Samsung Series 5 UltraTouch Battery Replacement, Remove the Back Cover: step 3, image 2 of 2
    • There are clips along the edges of the back cover that hold it in place. Be careful not to break these.
    • Remove the entire rest of the back cover.
  4. Samsung Series 5 UltraTouch Battery Replacement: step 4, image 1 of 2 Samsung Series 5 UltraTouch Battery Replacement: step 4, image 2 of 2
    • Remove the tape holding the wires in place.
  5. Samsung Series 5 UltraTouch Battery Replacement: step 5, image 1 of 1
    • Remove the following Phillips 00 screws securing the battery:
    • Four 4.5 mm screws
    • Two 6.7 mm Phillips screws
  6. Samsung Series 5 UltraTouch Battery Replacement, Remove the Battery: step 6, image 1 of 1
    • Pull the battery connector towards the battery to disconnect it.
  7. Samsung Series 5 UltraTouch Battery Replacement: step 7, image 1 of 1
    • Remove the battery from the laptop.
14 other people completed this guide.
Timothy
1,579 Reputation
5 Guides authored
USF Tampa, Team 16-3, Watkins Winter 2015 Member of USF Tampa, Team 16-3, Watkins Winter 2015
USFT-WATKINS-W15S16G3
4 Members
5 Guides authored
2 Comments
I have one question.. does the laptop operate without the battery? I want to take it out and not replace it.. thanks for your time..Chris
Chris - Reply
If you have a computer connected to a power supply that will still allow it to work.
Ruben Guardado -
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 61
All Time: 26,803
