Introduction
There are several steps that are required to remove the motherboard, some of which require some delicacy. This guide outlines the various steps, and notes the steps where caution is require.
Removal of the motherboard will take some time due to the various steps that are involved, so stay patient and do not rush.
Remove the battery by pushing out the locks on either end then pushing the battery away from you.
Using the J0 Japanese Industrial Standard screwdriver, remove the 4.5mm screw on the ODD/HDD Memory panel.
Using the J0 Japanese Industrial Standard screwdriver, remove the 4.5mm screw next to the label “ODD."
Remove the three 4.5mm screws from around the memory drive nest.
Using the J1 Japanese Industrial Standard screwdriver, remove the thirteen 9.5mm screws from the panel that cover the bottom of the computer.
Begin removing the computer casing by prying beside the disk drive with the iFixit opening tool and the spudger, working counterclockwise.
Lift the panel from the computer.
Using the J0 Japanese Industrial Standard screwdriver, remove the two 7mm screws that hold down the plug-in to the disc drive.
Using the J0 Japanese Industrial Standard screwdriver, remove the 3.5mm screw from the chip connected to the USB ports.
Using the J0 Japanese Industrial Standard screwdriver, remove the 4.5mm screw holding down the chip next to the power prongs where the battery connects.
Gently pull the chip from its connector.
Using the blunt tweezers, unthread the wires that connect the motherboard to the speakers from their holders, without crimping the wires.
Using the iFixit opening tool, gently pry up the plastic clasp that holds the keyboard power circuit down, and pull out the strip from the connection.
Using the J0 Japanese Industrial Standard screwdriver, remove the four 4.5mm screws from the corners of the motherboard.
Lift the motherboard from the computer.
