Samsung SPH-A500 Front LCD Display Replacement
  1. Samsung SPH-A500 Front LCD Display Replacement, Front LCD Display: step 1, image 1 of 1
    • Flip open the phone, remove the two rubber covers under the LCD screen.
    • Remove the two screws using a small Philips screwdriver.
  2. Samsung SPH-A500 Front LCD Display Replacement: step 2, image 1 of 1
    • Using a plastic opening tool, pry open the back cover of the LCD screen.
    • Note: Some force may be required.
  3. Samsung SPH-A500 Front LCD Display Replacement: step 3, image 1 of 1
    • Completely separate the back cover from the rest of the phone.
    • Close the phone.
  4. Samsung SPH-A500 Front LCD Display Replacement: step 4, image 1 of 1
    • The LCD screen is big, rectangular screen in the center of the logic board.
  5. Samsung SPH-A500 Front LCD Display Replacement: step 5, image 1 of 1
    • Remove the glue and black tape that is attached to the LCD screen
  6. Samsung SPH-A500 Front LCD Display Replacement: step 6, image 1 of 1
    • Remove Broken LCD Screen.
  7. Samsung SPH-A500 Front LCD Display Replacement: step 7, image 1 of 1
    • Attach the New LCD Screen, with wire point up and out to the black connector.
    • Note: Super Glue may be required to permanently attach LCD to the black connector
Derek Panger
21 Reputation
1 Guide authored
Cal Poly, Team 18-100, Johann Spring 2010 Member of Cal Poly, Team 18-100, Johann Spring 2010
CPSU-JOHANN-S10S18G100
4 Members
10 Guides authored
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 14
All Time: 2,453
