This teardown is not a repair guide. To repair your Samsung SGH-A117, use our service manual.
  1. Samsung SGH-A117: Breakdown and Reassembly, Samsumg SGH-A117: step 1, image 1 of 1
    • This is the Samsung SGH-A117.
  2. Samsung SGH-A117: Breakdown and Reassembly, Backside of the cellphone: step 2, image 1 of 1
    • This is the back view following the removal of the back cover and battery.
  3. Samsung SGH-A117: Breakdown and Reassembly, Removing Screws: step 3, image 1 of 1
    • Use a screwdriver to remove screws around the frame.
    • Use a PH00 size screw to operate this step.
    • The screws are extremely small. It is recommended to have a small container to keep track of the screws.
  4. Samsung SGH-A117: Breakdown and Reassembly, Removing the Back Cover: step 4, image 1 of 2 Samsung SGH-A117: Breakdown and Reassembly, Removing the Back Cover: step 4, image 2 of 2
    • Insert the spudger under the back cover at the marked locations and gently lift to remove the back cover.
    • The end of the phone closest to the hinge will require additional force to lift.
    • Be careful not to bend the cover during the removal process.
  5. Samsung SGH-A117: Breakdown and Reassembly, Separate Circuit Connector from Logic Board: step 5, image 1 of 1
    • Use a spudger to gently lift the circuit connector from the logic board.
    • Be careful not to remove the circuit connector from the phone.
  6. Samsung SGH-A117: Breakdown and Reassembly, Lift Logic Board: step 6, image 1 of 2 Samsung SGH-A117: Breakdown and Reassembly, Lift Logic Board: step 6, image 2 of 2
    • Use a spudger to lift the logic board and separate it from the main body of the phone.
    • It is recommended to lift from the bottom part of the logic board as shown in the picture.
    • Be careful not to lose the volume button, which is loosely attached to the logic board.
  7. Samsung SGH-A117: Breakdown and Reassembly, Remove Keypad: step 7, image 1 of 2 Samsung SGH-A117: Breakdown and Reassembly, Remove Keypad: step 7, image 2 of 2
    • Gently push the keyboard from the case as shown in the picture.
  8. Samsung SGH-A117: Breakdown and Reassembly, Layout of Disassembled Device: step 8, image 1 of 1
    • 1 Case
    • 1 Keyboard
    • 1 Logic Board
    • 1 Volume Control
    • 1 Back Cover
    • 5 Screws
Justin
150 Reputation
2 Guides authored
Aristotle Member of Aristotle
Community
5 Members
3 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 19
All Time: 796
