Samsung SCH-U340 Lower Casing Replacement
  1. Samsung SCH-U340 Lower Casing Replacement, Battery: step 1, image 1 of 1
    • Turn the cell phone so that the back side is facing you.
    • Press the upper indent and slide the back cover down.
  2. Samsung SCH-U340 Lower Casing Replacement: step 2, image 1 of 1
    • Pull the battery up from indent at the bottom and slide it out.
  3. Samsung SCH-U340 Lower Casing Replacement: step 3, image 1 of 1
    • Set the battery aside.
  4. Samsung SCH-U340 Lower Casing Replacement, Lower Casing: step 4, image 1 of 1
    • The lower casing is held on by four screws in the corner of the battery enclosure. Remove these screws.
  5. Samsung SCH-U340 Lower Casing Replacement: step 5, image 1 of 2 Samsung SCH-U340 Lower Casing Replacement: step 5, image 2 of 2
    • Use a spudger to pry the back assembly off of the device.
Anish Sambamurthy
31 Reputation
2 Guides authored
Cal Poly, Team 3-21, Maness Winter 2010 Member of Cal Poly, Team 3-21, Maness Winter 2010
CPSU-MANESS-W10S3G21
4 Members
10 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 3,620
