Samsung SC MX-20 Lens Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
10
Past 30 Days:
66
All Time:
644
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
The lens of a camcorder is one of the most important components of the device. However, the lens is also susceptible to cracking and becoming dirty. A dirty/cracked lens may affect the outcome of the photographed results, so a replacement may be in order.
When the lens of a Samsung camcorder are damaged or non-functional, it would need to be replaced. This guide will show you how to remove the lens in your camcorder.
Tools
    1. Samsung SC MX-20 Lens  Replacement, Lens: step 1, image 1 of 3 Samsung SC MX-20 Lens  Replacement, Lens: step 1, image 2 of 3 Samsung SC MX-20 Lens  Replacement, Lens: step 1, image 3 of 3
      • Unscrew the eight 4mm screws using the Phillips #000 screwdriver.
      Ask FixBot
    2. Samsung SC MX-20 Lens  Replacement: step 2, image 1 of 3 Samsung SC MX-20 Lens  Replacement: step 2, image 2 of 3 Samsung SC MX-20 Lens  Replacement: step 2, image 3 of 3
      • Unplug the cord connecting the LCD section of the device.
      • Remove the left face of the device.
      • Remove the top face by removing the three 4mm screws using a Phillips #000 screwdriver.
      Ask FixBot
    3. Samsung SC MX-20 Lens  Replacement: step 3, image 1 of 3 Samsung SC MX-20 Lens  Replacement: step 3, image 2 of 3 Samsung SC MX-20 Lens  Replacement: step 3, image 3 of 3
      • After removing the body of the device, unscrew the two 3.5mm Phillips #000 screws holding the battery compartment in place.
      • Remove the battery compartment.
      Ask FixBot
    4. Samsung SC MX-20 Lens  Replacement: step 4, image 1 of 3 Samsung SC MX-20 Lens  Replacement: step 4, image 2 of 3 Samsung SC MX-20 Lens  Replacement: step 4, image 3 of 3
      • Remove the lens assembly from the device.
      Ask FixBot
    5. Samsung SC MX-20 Lens  Replacement: step 5, image 1 of 3 Samsung SC MX-20 Lens  Replacement: step 5, image 2 of 3 Samsung SC MX-20 Lens  Replacement: step 5, image 3 of 3
      • Remove the three 3.5mm Phillips #000 screws on the metal part from the lens component.
      • Remove the motherboard from the lens.
      • Remove the lens from the lens assembly.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 66
All Time: 644
