Up to 20% off select tools
Samsung S760 Battery Cover Replacement Guide
View statistics:
Past 24 Hours:
0
Past 7 Days:
2
Past 30 Days:
6
All Time:
229
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 15 minutes
Difficulty: Easy
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Tools
Introduction
Go to step 1 ↓
The battery cover can break off fairly easily if you're not careful, as it is attached by only a single hinge. This guide will show you how to replace it.
    1. Samsung S760 Battery Cover  Replacement Guide, Battery: step 1, image 1 of 3 Samsung S760 Battery Cover  Replacement Guide, Battery: step 1, image 2 of 3 Samsung S760 Battery Cover  Replacement Guide, Battery: step 1, image 3 of 3
      • Placing your thumb on the battery cover, push outwards, away from the camera in the direction the arrow is pointing. If done correctly when it's completely unhooked, the latch will open.
      Ask FixBot
    2. Samsung S760 Battery Cover  Replacement Guide: step 2, image 1 of 2 Samsung S760 Battery Cover  Replacement Guide: step 2, image 2 of 2
      • Tip the camera as to gently slide the batteries out of the camera.
      Ask FixBot
    1. Samsung S760 Battery Cover  Replacement Guide, Front and Back Case: step 3, image 1 of 3 Samsung S760 Battery Cover  Replacement Guide, Front and Back Case: step 3, image 2 of 3 Samsung S760 Battery Cover  Replacement Guide, Front and Back Case: step 3, image 3 of 3
      • All screws in this camera are removed using the Phillip Screwdriver #000 bit. Also, all dimensions included refer to screw lengths.
      • Locate and remove the six 4mm screws on the sides of the camera.
      Ask FixBot
    2. Samsung S760 Battery Cover  Replacement Guide: step 4, image 1 of 2 Samsung S760 Battery Cover  Replacement Guide: step 4, image 2 of 2
      • Use the plastic opening tool to pry open the back case, following alongside the edge of the case if need be.
      Ask FixBot
    3. Samsung S760 Battery Cover  Replacement Guide: step 5, image 1 of 1
      • Once the back case is removed, use the plastic opening tool to gently pry off the front case.
      Ask FixBot
    1. Samsung S760 Battery Cover  Replacement Guide, Battery Cover: step 6, image 1 of 1
      • Using the pointed end of the Spudger, push the metal pin out of the hinge as far as it will go (this will typically be halfway).
      • It can be hard to get the Spudger point to center on the pin, so try choking up on the Spudger.
      Ask FixBot
    2. Samsung S760 Battery Cover  Replacement Guide: step 7, image 1 of 2 Samsung S760 Battery Cover  Replacement Guide: step 7, image 2 of 2
      Tool used on this step:
      Buy
      • Using the tweezers, grasp and pull the portion of the pin that is sticking out of the hinge.
      Ask FixBot
    3. Samsung S760 Battery Cover  Replacement Guide: step 8, image 1 of 2 Samsung S760 Battery Cover  Replacement Guide: step 8, image 2 of 2
      • Pull the battery cover in the same direction you pushed to open it. The cover should come right off.
      Ask FixBot
Author
with
Isaiah Weidmann
366 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 229
