Introduction
A tweeter speaker its the speaker that drives the highest range of frequency in the speaker. This guide will serve as a reference to replace the speaker/tweeter in the Samsung Radiant 360 R1 in the case that it becomes damaged.
Use the plastic opening tool to lift and remove the rubber grommet plugs.
While stabilizing the Port Panel remove the two ribbon cables one at a time by pressing the locking clip down on the ribbon cable connectors and pulling the connector away from the Port Panel.
I understand this is a guide for working on the Samsung wam 1500 yourself. But where can you get the parts from. I can not find them online. I need to replace the usb/power port panel
Remove the four (9.5mm x 1.6mm) PH1 Phillips screws on the port speaker body.
Remove the Port Panel exposing the subwoofer.
3 other people completed this guide.
