Samsung Powerbot R9250 Wheel Replacement
  1. Samsung Powerbot R9250 Wheel Replacement, Wheel: step 1, image 1 of 1
    • Flip the bot onto its side with the wheel you want to remove on top.
  2. Samsung Powerbot R9250 Wheel Replacement: step 2, image 1 of 1
    • Remove the round white cap on the outside of the wheel.
  3. Samsung Powerbot R9250 Wheel Replacement: step 3, image 1 of 1
    • Next, pry and remove the white casing that runs around the back round part of the bot.
  4. Samsung Powerbot R9250 Wheel Replacement: step 4, image 1 of 1
    • Continue until the whole white casing comes off.
  5. Samsung Powerbot R9250 Wheel Replacement: step 5, image 1 of 1
    • For the wheel you want to remove, there is a small square opening on outer black protective layer still around the wheel. Locate the screw that is inside the whole. Remove this screw.
  6. Samsung Powerbot R9250 Wheel Replacement: step 6, image 1 of 2 Samsung Powerbot R9250 Wheel Replacement: step 6, image 2 of 2
    • Pry the black protective layer away from the wheel, and pull the wheel out.
Ethen Sanchez
552 Reputation
5 Guides authored
Cal Poly, Team 10-3, Banghart Winter 2017 Member of Cal Poly, Team 10-3, Banghart Winter 2017
CPSU-BANGHART-W17S10G3
3 Members
10 Guides authored
One Comment
Hi Ethen. I've recently replaced both wheel kits on the same model powerbot you are working on in this guide. When I turn it on now it becomes absolutely possessed. Goes much faster than normal and moved erratically. I am wondering if you have ever experienced this or have heard of this.
Cameron Curran - Reply
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 10
All Time: 2,858
