Samsung Portable Dualband Tri-Mode External Speaker Replacement
  1. Samsung Portable Dualband Tri-Mode External Speaker Replacement, Battery: step 1, image 1 of 2 Samsung Portable Dualband Tri-Mode External Speaker Replacement, Battery: step 1, image 2 of 2
    • Slide the battery out from the battery compartment on the back of the phone.
  2. Samsung Portable Dualband Tri-Mode External Speaker Replacement, Antenna: step 2, image 1 of 2 Samsung Portable Dualband Tri-Mode External Speaker Replacement, Antenna: step 2, image 2 of 2
    • Unscrew the antenna top.
  3. Samsung Portable Dualband Tri-Mode External Speaker Replacement: step 3, image 1 of 3 Samsung Portable Dualband Tri-Mode External Speaker Replacement: step 3, image 2 of 3 Samsung Portable Dualband Tri-Mode External Speaker Replacement: step 3, image 3 of 3
    • Clasp the antenna with tweezers and push toward the top.
    • Remove the antenna.
  4. Samsung Portable Dualband Tri-Mode External Speaker Replacement, Backplate: step 4, image 1 of 3 Samsung Portable Dualband Tri-Mode External Speaker Replacement, Backplate: step 4, image 2 of 3 Samsung Portable Dualband Tri-Mode External Speaker Replacement, Backplate: step 4, image 3 of 3
    • Remove the four screws (3 mm) from the battery compartment.
    • Press the release buttons located on the side of the phone while gently prying the back plate off.
  5. Samsung Portable Dualband Tri-Mode External Speaker Replacement, Motherboard: step 5, image 1 of 3 Samsung Portable Dualband Tri-Mode External Speaker Replacement, Motherboard: step 5, image 2 of 3 Samsung Portable Dualband Tri-Mode External Speaker Replacement, Motherboard: step 5, image 3 of 3
    • Press the release tabs on the sides of the back casing.
    • Gently pry the motherboard loose and remove it.
  6. Samsung Portable Dualband Tri-Mode External Speaker Replacement, External Speaker: step 6, image 1 of 3 Samsung Portable Dualband Tri-Mode External Speaker Replacement, External Speaker: step 6, image 2 of 3 Samsung Portable Dualband Tri-Mode External Speaker Replacement, External Speaker: step 6, image 3 of 3
    • Locate the back plate of the phone. Turn the back plate over to view the inside.
    • Remove the 2 mm screw from the top of the inner back casing of the phone.
  7. Samsung Portable Dualband Tri-Mode External Speaker Replacement: step 7, image 1 of 2 Samsung Portable Dualband Tri-Mode External Speaker Replacement: step 7, image 2 of 2
    • With the flat head screwdriver, remove the external speaker unit.
  8. Samsung Portable Dualband Tri-Mode External Speaker Replacement: step 8, image 1 of 2 Samsung Portable Dualband Tri-Mode External Speaker Replacement: step 8, image 2 of 2
    • Take the external speaker unit and turn it over.
    • Remove the black rubber casing.
  9. Samsung Portable Dualband Tri-Mode External Speaker Replacement: step 9, image 1 of 2 Samsung Portable Dualband Tri-Mode External Speaker Replacement: step 9, image 2 of 2
    • Use tweezers to remove the external speaker from the small unit.
Barbara
413 Reputation
4 Guides authored
Clemson, Team 6-2, Benson Spring 2014 Member of Clemson, Team 6-2, Benson Spring 2014
CLEM-BENSON-S14S6G2
4 Members
14 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 3
All Time: 216
