Introduction
Replace the left wheel of your POWERbot. This can be done to resolve a persistent error code (C 02) and/or to simply eliminate movement issues.
Slide the plastic opening tool to the left, remaining under the black cover, until two left side pins have been detached. Then slide the plastic opening tool to the right until two right side pins have been detached.
Grab the two clips near the front of the black cover, on in front of each wheel. Pull the clips away from the wheels.
Remove the two 5mm Phillips #1 screws in the holes closest to the left wheel.
26 other people completed this guide.
9 Comments
Thanks for the info but can you tell me where I can get the wheel assembly as I think the motor has burned out. Thanks
Thank you so much :) … You helped me save all the money that I have spent on the Samsung Powerbot as I thought there is no way to fix it !
Can't Thank you enough Kyle ;)
Thanks for your information, also I would like to find the spare parts of wheel assembly . Can you recommend me for seller and prices?
October 23, 2018
Narit pukkapan
