Samsung POWERbot VR9000 Filter Replacement
    1. Samsung POWERbot VR9000 Filter Replacement, Filter: step 1, image 1 of 2 Samsung POWERbot VR9000 Filter Replacement, Filter: step 1, image 2 of 2
      • Turn off the emergency switch on the bottom of the power bot.
      Ask FixBot
    2. Samsung POWERbot VR9000 Filter Replacement: step 2, image 1 of 2 Samsung POWERbot VR9000 Filter Replacement: step 2, image 2 of 2
      • Gently pull up on the dustbin handle to to remove it from the rest of the power bot.
      Ask FixBot
    3. Samsung POWERbot VR9000 Filter Replacement: step 3, image 1 of 2 Samsung POWERbot VR9000 Filter Replacement: step 3, image 2 of 2
      • Push down on the yellow button to remove the dustbin cover.
      Ask FixBot
    4. Samsung POWERbot VR9000 Filter Replacement: step 4, image 1 of 3 Samsung POWERbot VR9000 Filter Replacement: step 4, image 2 of 3 Samsung POWERbot VR9000 Filter Replacement: step 4, image 3 of 3
      • Separate the dustbin cover from the filter.
      Ask FixBot
    5. Samsung POWERbot VR9000 Filter Replacement: step 5, image 1 of 2 Samsung POWERbot VR9000 Filter Replacement: step 5, image 2 of 2
      • Pull gently on the yellow tab to remove the filter from the cover.
      Ask FixBot
    6. Samsung POWERbot VR9000 Filter Replacement: step 6, image 1 of 1
      • The filter is removed. You can dispose of collected dust or rinse the filter with warm water before replacing.
      Ask FixBot
Josh Brouwer
164 Reputation
1 Guide authored
Cal Poly, Team S15-G3, Banghart Spring 2017 Member of Cal Poly, Team S15-G3, Banghart Spring 2017
CPSU-BANGHART-S17S15G3
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 104
All Time: 1,606
