Samsung NaviBot SR8981 (VCR8981L3B-XEG) Disassembly
  1. Samsung NaviBot SR8981 (VCR8981L3B-XEG) Disassembly, Remove the dust container: step 1, image 1 of 3 Samsung NaviBot SR8981 (VCR8981L3B-XEG) Disassembly, Remove the dust container: step 1, image 2 of 3 Samsung NaviBot SR8981 (VCR8981L3B-XEG) Disassembly, Remove the dust container: step 1, image 3 of 3
    • First, remove the dust container from the SR8981.
  2. Samsung NaviBot SR8981 (VCR8981L3B-XEG) Disassembly, Remove the battery: step 2, image 1 of 2 Samsung NaviBot SR8981 (VCR8981L3B-XEG) Disassembly, Remove the battery: step 2, image 2 of 2
    • Screw on the battery compartment at the green marked points and open the lid.
    • The blue arrow marks the connection between the battery and the housing. Once this is solved, the battery can be removed from the device.
    • Note: The orange arrow marks a USB interface that is likely to change the operating system or update it.
  3. Samsung NaviBot SR8981 (VCR8981L3B-XEG) Disassembly, Remove cover of cleaning brush: step 3, image 1 of 3 Samsung NaviBot SR8981 (VCR8981L3B-XEG) Disassembly, Remove cover of cleaning brush: step 3, image 2 of 3 Samsung NaviBot SR8981 (VCR8981L3B-XEG) Disassembly, Remove cover of cleaning brush: step 3, image 3 of 3
    • Open and remove the brush cover on the fixing clip (green arrow).
  4. Samsung NaviBot SR8981 (VCR8981L3B-XEG) Disassembly, Disassemble cleaning brush: step 4, image 1 of 3 Samsung NaviBot SR8981 (VCR8981L3B-XEG) Disassembly, Disassemble cleaning brush: step 4, image 2 of 3 Samsung NaviBot SR8981 (VCR8981L3B-XEG) Disassembly, Disassemble cleaning brush: step 4, image 3 of 3
    • The brush can be easily lifted out of the warehouse on the right and then removed to the right.
  5. Samsung NaviBot SR8981 (VCR8981L3B-XEG) Disassembly, Remove side panels: step 5, image 1 of 3 Samsung NaviBot SR8981 (VCR8981L3B-XEG) Disassembly, Remove side panels: step 5, image 2 of 3 Samsung NaviBot SR8981 (VCR8981L3B-XEG) Disassembly, Remove side panels: step 5, image 3 of 3
    • The first picture shows the side view.
    • Second picture: The plastic bracket (green arrow) of the side part must be carefully levered over the plastic nose (blue arrow). Subsequently, the side part can be pulled backwards.
    • Third picture: The side panel has been pulled back, now the plastic bracket (green arrow) and the plastic nose (blue arrow) are clearly visible.
  6. Samsung NaviBot SR8981 (VCR8981L3B-XEG) Disassembly, Disassemble the upper cover plate: step 6, image 1 of 3 Samsung NaviBot SR8981 (VCR8981L3B-XEG) Disassembly, Disassemble the upper cover plate: step 6, image 2 of 3 Samsung NaviBot SR8981 (VCR8981L3B-XEG) Disassembly, Disassemble the upper cover plate: step 6, image 3 of 3
    • Loosen screws on the left (first picture) and on the right
    • Second picture: carefully loosen the plastic claw and pry off the cover plate.
    • Third picture: the NaviBot without cover plate
  7. Samsung NaviBot SR8981 (VCR8981L3B-XEG) Disassembly, Remove intermediate level: step 7, image 1 of 2 Samsung NaviBot SR8981 (VCR8981L3B-XEG) Disassembly, Remove intermediate level: step 7, image 2 of 2
    • Remove the marked screws (green arrows) and remove the intermediate level.
  8. Samsung NaviBot SR8981 (VCR8981L3B-XEG) Disassembly, Front sensor cover: step 8, image 1 of 3 Samsung NaviBot SR8981 (VCR8981L3B-XEG) Disassembly, Front sensor cover: step 8, image 2 of 3 Samsung NaviBot SR8981 (VCR8981L3B-XEG) Disassembly, Front sensor cover: step 8, image 3 of 3
    • To disassemble the front sensor cover, the six screws on the bottom (second picture) must be removed.
  9. Samsung NaviBot SR8981 (VCR8981L3B-XEG) Disassembly, Disconnect motherboard: step 9, image 1 of 3 Samsung NaviBot SR8981 (VCR8981L3B-XEG) Disassembly, Disconnect motherboard: step 9, image 2 of 3 Samsung NaviBot SR8981 (VCR8981L3B-XEG) Disassembly, Disconnect motherboard: step 9, image 3 of 3
    • Remove the screws on the green arrows.
    • Note: As you can see from the orange mark, I have numbered the connectors that do not explain themselves by their placement on both the connector and the connector. As a result, they are easier to reassign later.
    • Release the plug connections (Fig. 2). Caution: especially the rigid cable connections (Figure 3) are a bit difficult to open and can be damaged without the proper caution.
  10. Samsung NaviBot SR8981 (VCR8981L3B-XEG) Disassembly, Disassemble the sensor board: step 10, image 1 of 2 Samsung NaviBot SR8981 (VCR8981L3B-XEG) Disassembly, Disassemble the sensor board: step 10, image 2 of 2
    • Once the four front screws are loosened, the front tripartite sensor board can also be removed.
Follow the instructions in reverse, to reassamble the Device.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Juvallos
119 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 1,996
