Introduction
This guide will provide detailed steps to replace the hard drive in the Samsung device.
Wedge your fingers in between the upper case and the lower case
Gently pull the lower case away from the upper case to remove it
Using tweezers or your fingertips, carefully pull on the battery connector to disconnect it from the motherboard.
Using the tip of the spudger, flip up the small locking flap on the ZIF connector. Now you can pull the cable.
