Samsung NP510R5E-A01UB Display Replacement
  1. Samsung NP510R5E-A01UB Display Replacement, Hard Drive: step 1, image 1 of 1
    • Make sure the device is powered off before beginning.
    • Using the Phillips #0 screwdriver, remove the 6.5mm long screw in the area circled.
  2. Samsung NP510R5E-A01UB Display Replacement: step 2, image 1 of 1
    • With the cover removed, unscrew all four of the 4.75mm long screws using the Phillips #0 screwdriver.
  3. Samsung NP510R5E-A01UB Display Replacement: step 3, image 1 of 2 Samsung NP510R5E-A01UB Display Replacement: step 3, image 2 of 2
    • Unplug the connector from the hard drive by pulling straight out.
  4. Samsung NP510R5E-A01UB Display Replacement, Display: step 4, image 1 of 3 Samsung NP510R5E-A01UB Display Replacement, Display: step 4, image 2 of 3 Samsung NP510R5E-A01UB Display Replacement, Display: step 4, image 3 of 3
    • Remove the two rubber feet with arrows by them on the back side to uncover two screws.
    • Unscrew the four silver 4.4mm long screws near the hard drive.
    • Unscrew the remaining nine black 6.5mm long screws. Then remove the back casing using a pry tool if needed.
  5. Samsung NP510R5E-A01UB Display Replacement: step 5, image 1 of 2 Samsung NP510R5E-A01UB Display Replacement: step 5, image 2 of 2
    • Disconnect the black and white cables by pulling up as pictured.
  6. Samsung NP510R5E-A01UB Display Replacement: step 6, image 1 of 2 Samsung NP510R5E-A01UB Display Replacement: step 6, image 2 of 2
    • Disconnect the black cable by pulling straight out.
  7. Samsung NP510R5E-A01UB Display Replacement: step 7, image 1 of 3 Samsung NP510R5E-A01UB Display Replacement: step 7, image 2 of 3 Samsung NP510R5E-A01UB Display Replacement: step 7, image 3 of 3
    • Unscrew the two 4.45mm long screws to disconnect the left hinge.
    • Unscrew the two 4.45mm long screws to disconnect the right hinge.
    • At this point the screen and plastic housing should be completely disconnected.
  8. Samsung NP510R5E-A01UB Display Replacement: step 8, image 1 of 2 Samsung NP510R5E-A01UB Display Replacement: step 8, image 2 of 2
    • Using the plastic opening tool, pry open the plastic housing that holds the display.
  9. Samsung NP510R5E-A01UB Display Replacement: step 9, image 1 of 2 Samsung NP510R5E-A01UB Display Replacement: step 9, image 2 of 2
    • Unscrew the four 3.55mm long screws that hold the display in place.
  10. Samsung NP510R5E-A01UB Display Replacement: step 10, image 1 of 2 Samsung NP510R5E-A01UB Display Replacement: step 10, image 2 of 2
    • Disconnect the last cable by pulling straight out.
Dominic Simpson
245 Reputation
1 Guide authored
USF Tampa, Team S6-G5, Eyestone Spring 2018 Member of USF Tampa, Team S6-G5, Eyestone Spring 2018
USFT-EYESTONE-S18S6G5
3 Members
8 Guides authored
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 13
All Time: 670
