Samsung NP270E5E-K03US RAM Replacement
  1. Samsung NP270E5E-K03US RAM Replacement, Battery: step 1, image 1 of 2 Samsung NP270E5E-K03US RAM Replacement, Battery: step 1, image 2 of 2
    • Begin with the laptop lying to its back revealing its underside.
    • Locate the two latches on the bottom of the laptop. Slide the latches inward until a faint click is heard.
  2. Samsung NP270E5E-K03US RAM Replacement: step 2, image 1 of 2 Samsung NP270E5E-K03US RAM Replacement: step 2, image 2 of 2
    • Completely remove the battery from the laptop.
  3. Samsung NP270E5E-K03US RAM Replacement, RAM: step 3, image 1 of 1
    • Begin with the laptop flipped upside down. Locate the single 4mm screw holding the small plastic cover to the laptop.
  4. Samsung NP270E5E-K03US RAM Replacement: step 4, image 1 of 3 Samsung NP270E5E-K03US RAM Replacement: step 4, image 2 of 3 Samsung NP270E5E-K03US RAM Replacement: step 4, image 3 of 3
    • Once the screw holding the cover down has been removed the cover can then be removed by sliding the cover in the direction of the gray arrow on the laptop.
    • The cover can then be removed to reveal the laptops RAM boards and also the laptops hard drive.
  5. Samsung NP270E5E-K03US RAM Replacement: step 5, image 1 of 3 Samsung NP270E5E-K03US RAM Replacement: step 5, image 2 of 3 Samsung NP270E5E-K03US RAM Replacement: step 5, image 3 of 3
    • The RAM boards are each held in place by a pair of spring latches (indicated by red circles) which must be disengaged.
    • To disengage the latches you must push them gently outwards until a soft click is heard.
    • If you are successful in disengaging the latches the RAM board will pop upwards allowing for easy removal.
  6. Samsung NP270E5E-K03US RAM Replacement: step 6, image 1 of 1
    • You can now pull the RAM board from the housing freeing up space for your new replacement RAM board.
    • Do not try to remove the RAM before the latches have disengaged and the RAM has popped up, otherwise risk damaging the computer / components.
Kyle Golden
353 Reputation
3 Guides authored
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 15
All Time: 1,075
