Samsung NP-130-JA01US RAM Replacement
  1. Samsung NP-130-JA01US RAM Replacement, Battery: step 1, image 1 of 1
    • Turn off the computer.
    • Disconnect the charger cable from the computer.
    • Failure to disconnect the charger cable from the computer could result in an electric shock.
    • Flip the computer over so the underside is facing up.
  2. Samsung NP-130-JA01US RAM Replacement: step 2, image 1 of 2 Samsung NP-130-JA01US RAM Replacement: step 2, image 2 of 2
    • Slide the left and right slider buttons fully away from each other.
  3. Samsung NP-130-JA01US RAM Replacement: step 3, image 1 of 1
    • Pull the battery out of the computer.
  4. Samsung NP-130-JA01US RAM Replacement, RAM: step 4, image 1 of 2 Samsung NP-130-JA01US RAM Replacement, RAM: step 4, image 2 of 2
    • Locate the "Memory" panel on the bottom right corner.
    • Use the Phillips 01 screwdriver to remove the screw.
    • The screw is a Phillips 1 (PH 1) with a length of 60 millimeters (mm)
  5. Samsung NP-130-JA01US RAM Replacement: step 5, image 1 of 1
    • With your hand, lift panel and remove it.
  6. Samsung NP-130-JA01US RAM Replacement: step 6, image 1 of 2 Samsung NP-130-JA01US RAM Replacement: step 6, image 2 of 2
    • Slide metal prongs (marked in red squares) away from each other with your fingers.
    • The RAM chip will automatically lift up at an angle for easy ejection.
  7. Samsung NP-130-JA01US RAM Replacement: step 7, image 1 of 1
    • With your hands, carefully slide the RAM chip out to remove.
    • The RAM chip is delicate, do not force it when removing it.
Jason Schnebelen
267 Reputation
2 Guides authored
USF Tampa, Team 9-6, Lacy Fall 2016 Member of USF Tampa, Team 9-6, Lacy Fall 2016
USFT-LACY-F16S9G6
3 Members
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 13
All Time: 211
