Samsung NP N310 HAA2US RAM Replacement
  1. Samsung NP N310 HAA2US RAM Replacement, Battery: step 1, image 1 of 3 Samsung NP N310 HAA2US RAM Replacement, Battery: step 1, image 2 of 3 Samsung NP N310 HAA2US RAM Replacement, Battery: step 1, image 3 of 3
    • Make sure the laptop is powered off, and unplugged before removing the battery.
    • Slide the battery switch to the unlock symbol, and the battery will pop up.
    • Remove the battery.
  2. Samsung NP N310 HAA2US RAM Replacement, RAM: step 2, image 1 of 3 Samsung NP N310 HAA2US RAM Replacement, RAM: step 2, image 2 of 3 Samsung NP N310 HAA2US RAM Replacement, RAM: step 2, image 3 of 3
    • Locate and unscrew the 5mm screw on the small panel on the back that has 'memory' written on it.
    • Pull off the memory panel.
  3. Samsung NP N310 HAA2US RAM Replacement: step 3, image 1 of 3 Samsung NP N310 HAA2US RAM Replacement: step 3, image 2 of 3 Samsung NP N310 HAA2US RAM Replacement: step 3, image 3 of 3
    • Pull the 2 latches holding the RAM in, away from the RAM stick, and the RAM will pop up.
    • Pull the RAM out of the slot, only touching the edges of the RAM stick
Amir Afridi
626 Reputation
6 Guides authored
USF Tampa, Team 4-1, Passmore Fall 2016 Member of USF Tampa, Team 4-1, Passmore Fall 2016
USFT-PASSMORE-F16S4G1
4 Members
6 Guides authored
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 12
All Time: 289
