Disassembling Kodak Advantix F350 Back Cover
Views: 1.8K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
97
All Time:
1,806
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Disassembling Kodak Advantix F350 Back Cover, Back Cover: step 1, image 1 of 1
      • Turn off the camera.
      • Locate the power switch on the front of the camera below the camera lens.
      • Slide the switch to the off position.
      Ask FixBot
    2. Disassembling Kodak Advantix F350 Back Cover: step 2, image 1 of 2 Disassembling Kodak Advantix F350 Back Cover: step 2, image 2 of 2
      • Locate the 3 screws that hold the back cover to the camera.
      • One screw is located on the film opener side of the camera.
      • The other screws are located on the opposite side of the camera.
      Ask FixBot
    3. Disassembling Kodak Advantix F350 Back Cover: step 3, image 1 of 3 Disassembling Kodak Advantix F350 Back Cover: step 3, image 2 of 3 Disassembling Kodak Advantix F350 Back Cover: step 3, image 3 of 3
      • Use the Phillips #00 Precision Screwdriver and remove the screws on the back cover.
      Ask FixBot
    4. Disassembling Kodak Advantix F350 Back Cover: step 4, image 1 of 2 Disassembling Kodak Advantix F350 Back Cover: step 4, image 2 of 2
      • Open the film door to remove the back cover.
      • Slide the film door lever to the left until the film door opens.
      Ask FixBot
    5. Disassembling Kodak Advantix F350 Back Cover: step 5, image 1 of 2 Disassembling Kodak Advantix F350 Back Cover: step 5, image 2 of 2
      • Use a plastic opening tool to pry the case open until a small gap is present.
      • Repeat this process at the top and bottom of the film door to loosen it.
      Ask FixBot
    6. Disassembling Kodak Advantix F350 Back Cover: step 6, image 1 of 3 Disassembling Kodak Advantix F350 Back Cover: step 6, image 2 of 3 Disassembling Kodak Advantix F350 Back Cover: step 6, image 3 of 3
      • Grab the top and bottom of the case firmly as shown.
      • Gently remove the back of the camera case with a slight twisting motion.
      Ask FixBot
David Cottrell
103 Reputation
5 Guides authored
UW Stout, Team 1-2, Zhou Fall 2011 Member of UW Stout, Team 1-2, Zhou Fall 2011
UWSTOUT-ZHOU-F11S1G2
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 97
All Time: 1,806
