Installing Samsung Jack Antenna
  1. Installing Samsung Jack Antenna, Battery: step 1, image 1 of 1
    • Slide the battery cover downwards with pressure focused on the center of the cover.
    • Lift the cover off of the phone.
  2. Installing Samsung Jack Antenna: step 2, image 1 of 1
    • Grasp the bottom left and right corners of the battery and lift it from its housing.
  3. Installing Samsung Jack Antenna, Rear Case: step 3, image 1 of 1
    • Remove the four black 7.30 mm screws surrounding the battery housing using a Phillips #00 Screwdriver.
  4. Installing Samsung Jack Antenna: step 4, image 1 of 3 Installing Samsung Jack Antenna: step 4, image 2 of 3 Installing Samsung Jack Antenna: step 4, image 3 of 3
    • The rear case is firmly attached to the phone with clips. Do not be afraid to use a little extra force.
    • Insert the Plastic Opening Tool in between the front and rear cases.
    • Pry with the Plastic Opening Tool around all edges of the phone until you free all the clips.
  5. Installing Samsung Jack Antenna: step 5, image 1 of 1
    • Lift the rear case off of the phone.
  6. Installing Samsung Jack Antenna, Antenna: step 6, image 1 of 1
    • Remove the two silver 4.30 mm screws on either side of the antenna using a Phillip's #00 Screwdriver.
  7. Installing Samsung Jack Antenna: step 7, image 1 of 3 Installing Samsung Jack Antenna: step 7, image 2 of 3 Installing Samsung Jack Antenna: step 7, image 3 of 3
    • There is a wire under the antenna connecting it to the Motherboard. Do not pull off the antenna just yet.
    • Use a spudger to remove the wire connector under the antenna.
Paul Piller
56 Reputation
5 Guides authored
Cal Poly, Team 24-57, Amido Spring 2011 Member of Cal Poly, Team 24-57, Amido Spring 2011
CPSU-AMIDO-S11S24G57
4 Members
7 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 2,331
