Samsung Impression Camera Replacement
  1. Samsung Impression Camera Replacement, Battery: step 1, image 1 of 1
    • Orient the phone with the screen facing down.
    • Using your thumb, slide the back panel away from the camera to expose the battery.
  2. Samsung Impression Camera Replacement: step 2, image 1 of 2 Samsung Impression Camera Replacement: step 2, image 2 of 2
    • Insert the tip of the spudger on the left side of the battery, opposite the direction of the white arrow.
    • Pry the battery free. It will pivot in the direction of the white arrow.
  3. Samsung Impression Camera Replacement, Back Cover: step 3, image 1 of 1
    • Remove the six 3.5 mm screws using a Phillips #000 screwdriver. Make sure to unscrew in a counterclockwise direction.
  4. Samsung Impression Camera Replacement: step 4, image 1 of 1
    • Remove the back cover by gently prying around the top and bottom edges with the spudger.
    • It may help to slide the touchscreen upwards when removing the back panel.
    • The side buttons will become loose and will fall out, so put these in a safe place.
  5. Samsung Impression Camera Replacement, Circuit Board: step 5, image 1 of 1
    • To free the circuit board, remove the black wire that is holding it down.
    • You can remove the wire by gently prying up the gold terminator that is attached to the green circuit board. A gentle tug is all it should take.
  6. Samsung Impression Camera Replacement: step 6, image 1 of 2 Samsung Impression Camera Replacement: step 6, image 2 of 2
    • The circuit board will still be held on by a blue and black ribbon. Remove the entire circuit board by gently tugging the ribbon upwards.
  7. Samsung Impression Camera Replacement, Camera: step 7, image 1 of 2 Samsung Impression Camera Replacement, Camera: step 7, image 2 of 2
    • Turn the circuit board over.
    • The bottom of the camera will have a gold ribbon coming out of it which attaches to the circuit board.
    • Pull upwards on the blue rectangle where the gold ribbon ends. This will remove the camera from the circuit board.
Saul Villatoro
255 Reputation
7 Guides authored
Cal Poly, Team 8-10, Regan Spring 2011 Member of Cal Poly, Team 8-10, Regan Spring 2011
CPSU-REGAN-S11S8G10
4 Members
22 Guides authored
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 12
All Time: 1,578
