Installing Samsung Impression Back Cover
  1. Installing Samsung Impression Back Cover, Battery: step 1, image 1 of 1
    • Orient the phone with the screen facing down.
    • Using your thumb, slide the back panel away from the camera to expose the battery.
  2. Installing Samsung Impression Back Cover: step 2, image 1 of 2 Installing Samsung Impression Back Cover: step 2, image 2 of 2
    • Insert the tip of the spudger on the left side of the battery, opposite the direction of the white arrow.
    • Pry the battery free. It will pivot in the direction of the white arrow.
  3. Installing Samsung Impression Back Cover, Back Cover: step 3, image 1 of 1
    • Remove the 6 outer screws.
    • The screws should be 3.5 mm in length.
    • Put the screws in a safe place as they are very small and easy to lose.
  4. Installing Samsung Impression Back Cover: step 4, image 1 of 1
    • Snap off back the cover by gently prying around the top and bottom edges with a flat head screwdriver.
    • It may help to slide the touchscreen upwards when removing the back panel.
    • The side buttons will become loose and are prone to fall out, so put these in a safe place.
Saul Villatoro
255 Reputation
7 Guides authored
Cal Poly, Team 8-10, Regan Spring 2011 Member of Cal Poly, Team 8-10, Regan Spring 2011
CPSU-REGAN-S11S8G10
4 Members
22 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 1,702
