Samsung HMX-F90 Strap Side Outer Casing Replacement
  1. Samsung HMX-F90 Strap Side Outer Casing Replacement, Battery: step 1, image 1 of 3 Samsung HMX-F90 Strap Side Outer Casing Replacement, Battery: step 1, image 2 of 3 Samsung HMX-F90 Strap Side Outer Casing Replacement, Battery: step 1, image 3 of 3
    • Pull the release tab away from the battery.
    • Slide the battery towards the release tab and then pull the battery away from the camcorder.
  2. Samsung HMX-F90 Strap Side Outer Casing Replacement, Strap Side Outer Casing: step 2, image 1 of 2 Samsung HMX-F90 Strap Side Outer Casing Replacement, Strap Side Outer Casing: step 2, image 2 of 2
    • Rotate the camcorder so that the strap side is facing you.
    • Locate and remove the three 4.5mm Phillips #00 screws around the hand strap.
  3. Samsung HMX-F90 Strap Side Outer Casing Replacement: step 3, image 1 of 2 Samsung HMX-F90 Strap Side Outer Casing Replacement: step 3, image 2 of 2
    • Rotate the camcorder so that the battery slot is facing you.
    • Located in the top left corner of the battery slot, remove the 4.5mm Phillips #00 screw.
  4. Samsung HMX-F90 Strap Side Outer Casing Replacement: step 4, image 1 of 2 Samsung HMX-F90 Strap Side Outer Casing Replacement: step 4, image 2 of 2
    • Rotate the camcorder so you are looking at the bottom of the camcorder.
    • Locate and remove the last three 4.5mm Phillips #00 screws.
  5. Samsung HMX-F90 Strap Side Outer Casing Replacement: step 5, image 1 of 3 Samsung HMX-F90 Strap Side Outer Casing Replacement: step 5, image 2 of 3 Samsung HMX-F90 Strap Side Outer Casing Replacement: step 5, image 3 of 3
    • With both hands, pull the side strap apart from the rest of the camcorder.
Amir Harb
705 Reputation
6 Guides authored
USF Tampa, Team S13-G1, Boczar Fall 2017 Member of USF Tampa, Team S13-G1, Boczar Fall 2017
USFT-BOCZAR-F17S13G1
4 Members
12 Guides authored
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 13
All Time: 323
