Samsung Gear VR with Controller Motherboard Replacement
  1. Samsung Gear VR with Controller Motherboard Replacement, Controller Batteries: step 1, image 1 of 3 Samsung Gear VR with Controller Motherboard Replacement, Controller Batteries: step 1, image 2 of 3 Samsung Gear VR with Controller Motherboard Replacement, Controller Batteries: step 1, image 3 of 3
    • Turn the controller upside down to access the battery compartment.
    • The battery compartment is located on the opposite side of the buttons.
    • Press on the top of the battery plate and slide down to remove the cover.
  2. Samsung Gear VR with Controller Motherboard Replacement: step 2, image 1 of 3 Samsung Gear VR with Controller Motherboard Replacement: step 2, image 2 of 3 Samsung Gear VR with Controller Motherboard Replacement: step 2, image 3 of 3
    • Remove the AAA batteries using your fingers.
  3. Samsung Gear VR with Controller Motherboard Replacement, Controller Motherboard: step 3, image 1 of 2 Samsung Gear VR with Controller Motherboard Replacement, Controller Motherboard: step 3, image 2 of 2
    • Remove the four 5mm Phillips #000 screws.
  4. Samsung Gear VR with Controller Motherboard Replacement: step 4, image 1 of 1
    • Use the metal spudger to pry the back side of the controller apart from the front.
    • You will have to use the spudger in many different spots along the divide before trying to separate the pieces.
  5. Samsung Gear VR with Controller Motherboard Replacement: step 5, image 1 of 2 Samsung Gear VR with Controller Motherboard Replacement: step 5, image 2 of 2
    • Pull apart the two halves of the controller to access the motherboard.
  6. Samsung Gear VR with Controller Motherboard Replacement: step 6, image 1 of 3 Samsung Gear VR with Controller Motherboard Replacement: step 6, image 2 of 3 Samsung Gear VR with Controller Motherboard Replacement: step 6, image 3 of 3
    • Pry on the two pop connectors with the plastic opening tool to detach the motherboard.
    • Separate the motherboard and trackpad from the rear part of the controller.
2 other people completed this guide.
Jake Criscione
587 Reputation
3 Guides authored
Cal Poly, Team S18-G3, White Winter 2019 Member of Cal Poly, Team S18-G3, White Winter 2019
CPSU-WHITE-W19S18G3
4 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 12
All Time: 1,128
