Samsung Gear VR with Controller Inner Mask Replacement
    1. Samsung Gear VR with Controller Inner Mask Replacement, Inner Mask: step 1, image 1 of 3 Samsung Gear VR with Controller Inner Mask Replacement, Inner Mask: step 1, image 2 of 3 Samsung Gear VR with Controller Inner Mask Replacement, Inner Mask: step 1, image 3 of 3
      • Push the switch on the right-hand side of the device to separate the cover from the main body.
      • Pull the cover away from the main device.
      Ask FixBot
    2. Samsung Gear VR with Controller Inner Mask Replacement: step 2, image 1 of 3 Samsung Gear VR with Controller Inner Mask Replacement: step 2, image 2 of 3 Samsung Gear VR with Controller Inner Mask Replacement: step 2, image 3 of 3
      • Remove the four corner screw covers with a metal spudger.
      • The screw covers fly off when removed, so make sure to keep track of them.
      Ask FixBot
    3. Samsung Gear VR with Controller Inner Mask Replacement: step 3, image 1 of 3 Samsung Gear VR with Controller Inner Mask Replacement: step 3, image 2 of 3 Samsung Gear VR with Controller Inner Mask Replacement: step 3, image 3 of 3
      • Use a metal spudger to remove the screw cover centered at the top.
      Ask FixBot
    4. Samsung Gear VR with Controller Inner Mask Replacement: step 4, image 1 of 3 Samsung Gear VR with Controller Inner Mask Replacement: step 4, image 2 of 3 Samsung Gear VR with Controller Inner Mask Replacement: step 4, image 3 of 3
      • Remove the six 5mm Phillips #000 screws to detach the front phone mount.
      • Lift the front phone mount up and to the left.
      • Remove the front phone mount carefully because there is a wire harness on the left side of the headset.
      Ask FixBot
    5. Samsung Gear VR with Controller Inner Mask Replacement: step 5, image 1 of 2 Samsung Gear VR with Controller Inner Mask Replacement: step 5, image 2 of 2
      • Remove the four 5mm Phillips #000 screws that secure the plate on the left side of the headset.
      • Pull the plate away from the motherboard gently.
      Ask FixBot
    6. Samsung Gear VR with Controller Inner Mask Replacement: step 6, image 1 of 2 Samsung Gear VR with Controller Inner Mask Replacement: step 6, image 2 of 2
      • Use the iFixit opening tool to remove the pop connector holding the wire harness to the motherboard.
      • You can now completely remove the front phone mount from the headset.
      Ask FixBot
    7. Samsung Gear VR with Controller Inner Mask Replacement: step 7, image 1 of 3 Samsung Gear VR with Controller Inner Mask Replacement: step 7, image 2 of 3 Samsung Gear VR with Controller Inner Mask Replacement: step 7, image 3 of 3
      • Remove the rest of the pop connectors on the motherboard using the iFixit opening tool.
      • Pry at the top of the motherboard with the iFixit opening tool to remove the motherboard.
      • The largest pop connector may require more effort to remove.
      • Make sure that nothing is connected to the motherboard before you pull it out.
      Ask FixBot
    8. Samsung Gear VR with Controller Inner Mask Replacement: step 8, image 1 of 3 Samsung Gear VR with Controller Inner Mask Replacement: step 8, image 2 of 3 Samsung Gear VR with Controller Inner Mask Replacement: step 8, image 3 of 3
      • Remove the eight 5mm Phillips #000 screws on the inner mask.
      • Gently separate the inner mask from the headset by pulling the mask from the inner sides of the lens sockets.
      Ask FixBot
Harumi Hokari
243 Reputation
2 Guides authored
Cal Poly, Team S18-G3, White Winter 2019 Member of Cal Poly, Team S18-G3, White Winter 2019
CPSU-WHITE-W19S18G3
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 52
All Time: 631
