Samsung Gear S Display Replacement
  1. Samsung Gear S Display Replacement, Display: step 1, image 1 of 3 Samsung Gear S Display Replacement, Display: step 1, image 2 of 3 Samsung Gear S Display Replacement, Display: step 1, image 3 of 3
    • Remove the wrist strap by peeling back the rubber starting from one corner of the watch face. Continue peeling the rubber away from the watch face until the strap is completely off.
  2. Samsung Gear S Display Replacement: step 2, image 1 of 2 Samsung Gear S Display Replacement: step 2, image 2 of 2
    • Starting from an edge, wedge a metal spudger in between the screen and the chrome trim ring and pry, lifting the screen outwards.
    • Some force is needed due to adhesive seal.
  3. Samsung Gear S Display Replacement: step 3, image 1 of 1
    • Use a plastic opening tool to gently pry upwards on the plastic motherboard assembly.
  4. Samsung Gear S Display Replacement: step 4, image 1 of 1
    • Locate the ribbon assembly attaching the display to the motherboard.
  5. Samsung Gear S Display Replacement: step 5, image 1 of 1
    • Use a plastic opening tool to detach the glass screen/ LED Display ribbon connector from the motherboard.
  6. Samsung Gear S Display Replacement: step 6, image 1 of 1
    • Now the watch should be in three separate pieces.
Crystal Schmitt
679 Reputation
1 Guide authored
USF Tampa, Team 12-1, Blackwell Fall 2015 Member of USF Tampa, Team 12-1, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G1
4 Members
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 21
All Time: 15,477
