Introduction
This guide will walk you through the process of replacing a broken home button in a Samsung Gear 2.
To remove each strap, locate the metal latches on both sides of the back of the Gear.
Press down on the metal latch while pulling the strap away from the Gear until it is completely off.
Firmly holding the Gear, insert the flat side of the spudger at an angle to pry the back casing off of the device. Move the spudger along the sides of the Gear to completely detach the back and front components.
Pry the device open from the other side also if it does not fully disassemble from one side.
Insert the spudger into the small opening underneath the black home button assembly and pry it off the casing.
Lift up to detach the black assembly.
Use tweezers to grab the orange connector that is attached to side the home button assembly and lift to remove it from its adhesive.
Using two spudgers, place the pointed tips at each end of the U-shaped snap ring located under where the home button assembly was.
Remove the snap ring by pushing down with both pointed objects on each side of the ring simultaneously, it should pop off.
