Samsung Galaxy a20e Charging Board Replacement
  1. Samsung Galaxy a20e Charging Board Replacement, Remove the SIM card tray: step 1, image 1 of 1
    • Insert a SIM eject tool, a SIM eject screwdriver tip, or a straightened paperclip into the small hole on the SIM tray on the left side of the phone.
    • Press firmly with the eject tool to eject the SIM card tray.
    • Remove the SIM card tray.
    • When putting the cards back in place, be sure they are correctly oriented inside the tray.
  2. Samsung Galaxy a20e Charging Board Replacement, Cut the screen adhesive: step 2, image 1 of 3 Samsung Galaxy a20e Charging Board Replacement, Cut the screen adhesive: step 2, image 2 of 3 Samsung Galaxy a20e Charging Board Replacement, Cut the screen adhesive: step 2, image 3 of 3
    • Heat the screen surface by using a hairdryer or the iOpener.
    • Lift the display by using a suction cup in order to create a little gap between the phone back cover and the display.
    • Insert a opening pick or a thin tool in the gap and slide it along the entire edge to cut the adhesive.
    • Lift the display with the help of the suction cup to separate the display from the back cover.
  3. Samsung Galaxy a20e Charging Board Replacement, Removal of the charging board cover: step 3, image 1 of 2 Samsung Galaxy a20e Charging Board Replacement, Removal of the charging board cover: step 3, image 2 of 2
    • Remove the seven Philips #00 screws.
    • Remove the charging board cover.
  4. Samsung Galaxy a20e Charging Board Replacement: step 4, image 1 of 3 Samsung Galaxy a20e Charging Board Replacement: step 4, image 2 of 3 Samsung Galaxy a20e Charging Board Replacement: step 4, image 3 of 3
    • Disconnect the connector that connects the logic board.
    • Disconnect the white wire.
    • Disconnect the blue wire.
    • Unscrew the Philips #00 screw.
  5. Samsung Galaxy a20e Charging Board Replacement, Charging Board Removal: step 5, image 1 of 2 Samsung Galaxy a20e Charging Board Replacement, Charging Board Removal: step 5, image 2 of 2
    • Remove the charging board and replace it with the new one.
In order to reassemble your device, follow the instructions in reverse order.
Special thanks to these translators:
it en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Smilzo
12,083 Reputation
39 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 25
All Time: 534
