Samsung Galaxy XCover Pro Screen Replacement
    1. Samsung Galaxy XCover Pro Screen Replacement, Screen: step 1, image 1 of 1
      • Using a heat gun, or a hair dryer on high, heat the screen, focusing on the edges around the screen to melt the glue holding the screen on.
      Ask FixBot
    2. Samsung Galaxy XCover Pro Screen Replacement: step 2, image 1 of 1
      • After heating, insert picks around the barrier of the screen as wedges to help with pulling the screen off.
      • The screen will begin to pry off with the picks inserted; however, a suction cup can be used to assist in separating the screen from the casing.
      Ask FixBot
    3. Samsung Galaxy XCover Pro Screen Replacement: step 3, image 1 of 2 Samsung Galaxy XCover Pro Screen Replacement: step 3, image 2 of 2
      • Unclip the black tab covering the motherboard and screen ribbon cables.
      Ask FixBot
    4. Samsung Galaxy XCover Pro Screen Replacement: step 4, image 1 of 2 Samsung Galaxy XCover Pro Screen Replacement: step 4, image 2 of 2
      • Use a spudger or tweezers to pull the ribbon connecting the screen to the device, disconnecting it entirely.
      Ask FixBot
To reassemble the device, follow the steps in reverse order. New glue is not required to reattach the screen, as the previous glue will still be present and adhesive enough to attach the new screen. However, after reattaching ensure time for the old (or new) glue to settle.
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 41
Past 30 Days: 171
All Time: 542
