Introduction
This guide will first require the removal of the kickstand in order to access the battery. Removal of the back panel will require some force, and the help of a friend may be necessary. While removing the back panel there will be loud popping noises. This sound is the magnetized latches snapping off and is not doing damage to the device.
Place the device on a hard flat surface with its screen facing downwards.
Rotate the the kickstand so that the handle grip hole is up in the air and not touching the back of the tablet.
Stick the pointy end of the spudger into the circular opening of the leftmost metallic latch.
With the spudger still inserted, pry the spudger to the right pushing the latch opening along with it.
Once the latch is moved to the right, pull up on the left side of the kickstand, releasing it from the back of the tablet.
Repeat the previous steps for the rightmost latch, and then lift the kickstand off the back of the tablet.
Check the device is completely turned off.
Slide open the SD compartment tab, and remove the SD card to ensure all data is saved.
Insert the plastic opening tool between the seam of the back panel and the front casing to create an initial opening.
Insert the metal spudger within the opening.
Move the metal spudger down the seam, prying the back panel open as you go.
Once a large enough opening is made, pry the entire back panel off with your hand.
Remove the 6 screws (4 mm in length) using the Phillips #0 screwdriver.
Remove the battery from the device.
Si vous trouvez une batterie pour tablette Samsung Galaxy View lithium je serais acheteurs cyr.roland@bell.net merci.
What step 7 doesn’t mention is the battery connector must be gently pulled up to unplug from the main board and when installing the new battery gently push connector back onto the main board making sure it is properly lined up
40 other people completed this guide.
29 Comments
What size is the battery that fits into the SAMSUNG TAB VIEW?
I can't find Lithium ION 11.3 V 5700mAh battery for my Samsung Galaxy 18.4View Tablet, does anyone know where to get one?
What's difference between a 5700mAh battery and 5900mAh battery
Where can I find battery replacement for galaxy view
did you find out what battery goes in the Samsung view.. I need one
Thank you, thank you. It works great.
Thanks, I replaced my battery successfully. But the problem is still not charging. The result is still the same, when plugged in, the reading is at 90% then when unplugged, it will shut off. Any ideas? Thanks
Like instructions where can I find a battery for a galaxy
I really need help finding a battery for my Samsung Galaxy View … can anyone help?
They sell them online but they are hard to find i just bought one on Jan 5, 2021 expected to arrive on Jan 12, 2021 also i have one for sale if interested the whole tablet… Thank you
where can i buy a battery replacement for this?
Anyone found a battery, yet?
Go online they have them…
Bought this, and loved it. Perfect for reading books.
However, I am highly !#^&@@, that just a couple of years old, I cannot find a battery. Samsung has lost our business. &&^&^$^ ridiculous!
Go online that's where i bought mines from…
I order minds offline on Jan 5, 2021
I order my battery for the Samsung Galaxy view table offline on Jan 5, 2021 expected to be here on Jan 19, 2021
If anyone is interested in purchasing a new one i have one if your intrested thank you….
I have two batteries My main board is toast I think wont charge the batteries. I even replaced the charger port. I have two of those as well. I also have two charger cables. So far my View is dead and these changes did not help. I will sell the parts if you want them.
I want them! How can I get them? Battery for view?
What is the battery model. I need a replacement for the view 18.5 tablet?
Amazon lists 5 or 6 compatible batteries for the sm t670 View. Not cheap.
I went to Best Buys and they can get a battery and the cost in Nova Scotia, Canada is $200. I didn’t ask the price to have it installed.
Easy fix, ordered the battery from Ebay, about $80 and a 20 minute swap out and I have a new View!
