Samsung Galaxy Tab S2 SD Card Replacement
  1. Samsung Galaxy Tab S2 SD Card  Replacement, SD Card: step 1, image 1 of 1
    • Locate the small hole surrounded by a rectangle on the right side of the device.
  2. Samsung Galaxy Tab S2 SD Card  Replacement: step 2, image 1 of 2 Samsung Galaxy Tab S2 SD Card  Replacement: step 2, image 2 of 2
    • Using the tool supplied with the Galaxy Tab, insert the pointed end into the hole on the side of the device.
    • Apply pressure until the plastic SD card slot pops out.
    • Gently pull out the plastic insert completely.
  3. Samsung Galaxy Tab S2 SD Card  Replacement: step 3, image 1 of 1
    • Insert the Micro SD Card in the plastic insert, and replace it into the device.
    • This device can only handle SD cards with memory up to 64 GB.
Jovina Martinez
2,084 Reputation
7 Guides authored
USF Tampa, Team 10-4, Remmell Spring 2016 Member of USF Tampa, Team 10-4, Remmell Spring 2016
USFT-REMMELL-S16S10G4
4 Members
18 Guides authored
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 42
All Time: 5,402
