Samsung Galaxy Tab S2 9.7 Verizon Tablet Battery Replacement
  1. Samsung Galaxy Tab S2 9.7 Verizon Tablet Battery Replacement, Back Case: step 1, image 1 of 1
    • Turn off the tablet before disassembly.
    • Heat up an iOpener for 30 seconds and place on all four seams of the screen. A heat gun can be used as well.
  2. Samsung Galaxy Tab S2 9.7 Verizon Tablet Battery Replacement: step 2, image 1 of 2 Samsung Galaxy Tab S2 9.7 Verizon Tablet Battery Replacement: step 2, image 2 of 2
    • The glue is now melted, so using the metal spudger shown, pry open all sides of the tablet.
    • When prying open near the home and touch screen buttons, use a suction cup.
    • Do not stick the metal spudger past these buttons as this may damage your device.
  3. Samsung Galaxy Tab S2 9.7 Verizon Tablet Battery Replacement: step 3, image 1 of 2 Samsung Galaxy Tab S2 9.7 Verizon Tablet Battery Replacement: step 3, image 2 of 2
    • Carefully lift up the screen.
    • There is a ribbon cable attached. Lifting the screen too quickly can damage the cable.
  4. Samsung Galaxy Tab S2 9.7 Verizon Tablet Battery Replacement: step 4, image 1 of 3 Samsung Galaxy Tab S2 9.7 Verizon Tablet Battery Replacement: step 4, image 2 of 3 Samsung Galaxy Tab S2 9.7 Verizon Tablet Battery Replacement: step 4, image 3 of 3
    • Remove the ribbon cable using the Metal Spudger.
    • The ribbon may be taped underneath to the grey frame. Gently lift the ribbon to untape it.
  5. Samsung Galaxy Tab S2 9.7 Verizon Tablet Battery Replacement: step 5, image 1 of 2 Samsung Galaxy Tab S2 9.7 Verizon Tablet Battery Replacement: step 5, image 2 of 2
    • Remove all seventeen 3 mm screws using a PH000 Phillips screwdriver.
  6. Samsung Galaxy Tab S2 9.7 Verizon Tablet Battery Replacement: step 6, image 1 of 3 Samsung Galaxy Tab S2 9.7 Verizon Tablet Battery Replacement: step 6, image 2 of 3 Samsung Galaxy Tab S2 9.7 Verizon Tablet Battery Replacement: step 6, image 3 of 3
    • Lift the black frame using the two Metal Spudgers shown.
    • On the third picture, there is a Sim Card component that is connected to the frame and back cover. As you lift up the frame, it'll detach. This is normal.
  7. Samsung Galaxy Tab S2 9.7 Verizon Tablet Battery Replacement: step 7, image 1 of 1
    • Once lifted, flip the grey frame over.
    • This component connects to the sim card.
    • Remember to click this component back into place when reassembling the tablet.
  8. Samsung Galaxy Tab S2 9.7 Verizon Tablet Battery Replacement, Battery: step 8, image 1 of 3 Samsung Galaxy Tab S2 9.7 Verizon Tablet Battery Replacement, Battery: step 8, image 2 of 3 Samsung Galaxy Tab S2 9.7 Verizon Tablet Battery Replacement, Battery: step 8, image 3 of 3
    • Unclip the orange ribbon cable located above the battery using the Blunt ESD Tweezer.
    • Remove the four black 3mm screws using a PH000 Phillips screwdriver.
  9. Samsung Galaxy Tab S2 9.7 Verizon Tablet Battery Replacement: step 9, image 1 of 1
    • Hold the frame and pop the battery off from the other side.
Divya Prabakaran
633 Reputation
6 Guides authored
USF Tampa, Team S2-G4, Sullivan Spring 2017 Member of USF Tampa, Team S2-G4, Sullivan Spring 2017
USFT-SULLIVAN-S17S2G4
4 Members
12 Guides authored
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 25
All Time: 1,588
