Samsung Galaxy Tab Pro 8.4 Battery Replacement
  1. Samsung Galaxy Tab Pro 8.4 Battery Replacement, Battery: step 1, image 1 of 1
    • Begin by separating the back panel from the screen glass assembly using the plastic opening tool.
    • Insert the plastic opening tool between the edge of the glass screen and the metal frame around the device.
  2. Samsung Galaxy Tab Pro 8.4 Battery Replacement: step 2, image 1 of 2 Samsung Galaxy Tab Pro 8.4 Battery Replacement: step 2, image 2 of 2
    • Continue around the entire device until the back panel is completely separated from the screen.
  3. Samsung Galaxy Tab Pro 8.4 Battery Replacement: step 3, image 1 of 2 Samsung Galaxy Tab Pro 8.4 Battery Replacement: step 3, image 2 of 2
    • Remove the four 2.5mm Phillips #000 screws.
  4. Samsung Galaxy Tab Pro 8.4 Battery Replacement: step 4, image 1 of 1
    • Gently pull up on the plastic tab that has red, blue and black wires that connects the battery to the motherboard.
  5. Samsung Galaxy Tab Pro 8.4 Battery Replacement: step 5, image 1 of 1
    • The battery should be completely disconnected and the new one can be installed.
Jonathan Romine
1,072 Reputation
2 Guides authored
USF Tampa, Team 9-2, Lacy Fall 2016 Member of USF Tampa, Team 9-2, Lacy Fall 2016
USFT-LACY-F16S9G2
4 Members
10 Guides authored
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 39
All Time: 12,110
