Introduction
This guide will show you the steps to follow when replacing the display on your Samsung Galaxy Tab 4 8.0 Verizon.
Slightly apply pressure and move the blue plastic opening tool downwards to pop the metallic rectangular connector from its socket on the mother board.
Slightly apply pressure and move the blue plastic opening tool downwards to pop the gold rectangular connector from its socket on the mother board.
Slightly apply pressure and move the blue plastic opening tool downwards to pop the gold square connector from its socket on the mother board.
Remove two 2 mm #000 Phillips screws securing the metallic charger port cover to both the logic board and the front panel.
Carefully insert the flat end of the blue plastic opening tool under the black plastic fastener and lift.
Squeeze the golden cable with the tweezers and gently pull the cable to the left to free the end of the golden cable.
Wedge four of the opening picks in between the display screen and the device backing on all four corners.
Wedge the Jimmy between the display and the device backing at a corner.
Cut through the adhesive that is securing the screen to the device on all four sides.
Once the display is completely disconnected from the device gently remove it without touching the screen which lies underneath.
