Back Case Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Back Case Replacement, Back Case: step 1, image 1 of 3 Back Case Replacement, Back Case: step 1, image 2 of 3 Back Case Replacement, Back Case: step 1, image 3 of 3
    • Using a plastic opening tool, wedge in the seam between the screen and the case.
    • Rock the tool by moving it towards and away from the middle of the screen, trying to separate the tape holding the screen and case together.
    • This is a long process, so don't try and rush it. Also, be careful about applying pressure.
  2. Back Case Replacement: step 2, image 1 of 3 Back Case Replacement: step 2, image 2 of 3 Back Case Replacement: step 2, image 3 of 3
    • After separating the tape holding the screen and case together, slowly start taking the screen off the case from the opposite side of the side with the buttons
Kevin Hicks
1,575 Reputation
2 Guides authored
USF Tampa, Team 11-1, Cheng Spring 2016 Member of USF Tampa, Team 11-1, Cheng Spring 2016
USFT-CHENG-S16S11G1
4 Members
12 Guides authored
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 16
All Time: 3,787
