Samsung Galaxy Tab 3 7.0 Battery Replacement
  1. Samsung Galaxy Tab 3 7.0 Battery Replacement, Battery: step 1, image 1 of 2 Samsung Galaxy Tab 3 7.0 Battery Replacement, Battery: step 1, image 2 of 2
    • With a plastic opening tool, gently insert the prying end in between the glass digitizer and the silver frame from the front of the device.
  2. Samsung Galaxy Tab 3 7.0 Battery Replacement: step 2, image 1 of 3 Samsung Galaxy Tab 3 7.0 Battery Replacement: step 2, image 2 of 3 Samsung Galaxy Tab 3 7.0 Battery Replacement: step 2, image 3 of 3
    • Working slowly and carefully, move around the entirety of the face of the device. Small plastic clips should release, if not, apply gentle outwards pressure until you hear the clips popping off.
  3. Samsung Galaxy Tab 3 7.0 Battery Replacement: step 3, image 1 of 3 Samsung Galaxy Tab 3 7.0 Battery Replacement: step 3, image 2 of 3 Samsung Galaxy Tab 3 7.0 Battery Replacement: step 3, image 3 of 3
    • To begin actual removal of the battery itself, remove the four designated screws with your screwdriver.
    • Once the screws are removed, use either the tip of your screwdriver or a pair of tweezers to pull up the battery connector. Pull directly up and the connector should pop out.
    • Once the battery is removed, it should look as it does in the third picture.
  4. Samsung Galaxy Tab 3 7.0 Battery Replacement: step 4, image 1 of 1
    • To finish battery replacement, place your new battery where the old battery was in your device, as shown in the picture.
Ian Leonard
469 Reputation
1 Guide authored
Cal Poly, Team 7-20, Regan Spring 2014 Member of Cal Poly, Team 7-20, Regan Spring 2014
CPSU-REGAN-S14S7G20
4 Members
10 Guides authored
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 70
All Time: 165,460
