Samsung Galaxy Tab 3 10.1 Rear-Facing Camera Replacement
  1. Samsung Galaxy Tab 3 10.1 Rear-Facing Camera Replacement, Rear Case: step 1, image 1 of 2 Samsung Galaxy Tab 3 10.1 Rear-Facing Camera Replacement, Rear Case: step 1, image 2 of 2
    • Insert an opening pick between the rear case and the plastic rim.
    • You may need to add multiple picks to detach the clips.
    • Slide the pick along the edge of the rear case until you release the plastic clips attaching the rear case to the display.
    • Continue to slide the pick around the edge of the rear case until all clips are released.
  2. Samsung Galaxy Tab 3 10.1 Rear-Facing Camera Replacement: step 2, image 1 of 2 Samsung Galaxy Tab 3 10.1 Rear-Facing Camera Replacement: step 2, image 2 of 2
    • Lift the case up to remove it.
  3. Samsung Galaxy Tab 3 10.1 Rear-Facing Camera Replacement, Battery: step 3, image 1 of 3 Samsung Galaxy Tab 3 10.1 Rear-Facing Camera Replacement, Battery: step 3, image 2 of 3 Samsung Galaxy Tab 3 10.1 Rear-Facing Camera Replacement, Battery: step 3, image 3 of 3
    • Use the flat end of a nlyon spudger to pry up the black plastic tabs securing the two ZIF connectors.
  4. Samsung Galaxy Tab 3 10.1 Rear-Facing Camera Replacement: step 4, image 1 of 2 Samsung Galaxy Tab 3 10.1 Rear-Facing Camera Replacement: step 4, image 2 of 2
    • Use the flat end of a nylon spudger to pry up the brown plastic tab securing the orange ribbon cable.
  5. Samsung Galaxy Tab 3 10.1 Rear-Facing Camera Replacement: step 5, image 1 of 3 Samsung Galaxy Tab 3 10.1 Rear-Facing Camera Replacement: step 5, image 2 of 3 Samsung Galaxy Tab 3 10.1 Rear-Facing Camera Replacement: step 5, image 3 of 3
    • Remove all three ribbon cables by gently pulling the cables away from the ZIF connectors.
  6. Samsung Galaxy Tab 3 10.1 Rear-Facing Camera Replacement: step 6, image 1 of 1
    • Use a Phillips #000 screwdriver to remove the ten 3mm screws securing the battery to the chassis.
  7. Samsung Galaxy Tab 3 10.1 Rear-Facing Camera Replacement: step 7, image 1 of 2 Samsung Galaxy Tab 3 10.1 Rear-Facing Camera Replacement: step 7, image 2 of 2
    • Use the pointed end of a nylon spudger to pry the two battery connections away from the motherboard.
  8. Samsung Galaxy Tab 3 10.1 Rear-Facing Camera Replacement: step 8, image 1 of 2 Samsung Galaxy Tab 3 10.1 Rear-Facing Camera Replacement: step 8, image 2 of 2
    • Lift with a nylon spudger to remove the battery.
  9. Samsung Galaxy Tab 3 10.1 Rear-Facing Camera Replacement, Rear-Facing Camera: step 9, image 1 of 3 Samsung Galaxy Tab 3 10.1 Rear-Facing Camera Replacement, Rear-Facing Camera: step 9, image 2 of 3 Samsung Galaxy Tab 3 10.1 Rear-Facing Camera Replacement, Rear-Facing Camera: step 9, image 3 of 3
    • Use the flat end of a plastic spudger to pry up the press-fit connector from the motherboard.
    • Remove the camera by gently pulling upward with a pair of tweezers.
Corey Brown
8,691 Reputation
11 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 17
All Time: 727
