Insert an opening pick between the rear case and the plastic rim.
Slide the pick along the edge of the rear case until you release the plastic clips attaching the rear case to the display.
Continue to slide the pick around the edge of the rear case until all clips are released.
Use the flat end of a nlyon spudger to pry up the black plastic tabs securing the two ZIF connectors.
Use the flat end of a nylon spudger to pry up the brown plastic tab securing the orange ribbon cable.
Use a Phillips #000 screwdriver to remove the ten 3mm screws securing the battery to the chassis.
Use the pointed end of a nylon spudger to pry the two battery connections away from the motherboard.
