Samsung Galaxy Tab 10.1 Rear Panel Replacement
  1. Samsung Galaxy Tab 10.1 Rear Panel Replacement, Rear Panel: step 1, image 1 of 2 Samsung Galaxy Tab 10.1 Rear Panel Replacement, Rear Panel: step 1, image 2 of 2
    • Place the bottom of the tablet towards you.
    • Remove the two 4.1 mm screws near the charge port with a Tri-Wing screwdriver.
  2. Samsung Galaxy Tab 10.1 Rear Panel Replacement: step 2, image 1 of 3 Samsung Galaxy Tab 10.1 Rear Panel Replacement: step 2, image 2 of 3 Samsung Galaxy Tab 10.1 Rear Panel Replacement: step 2, image 3 of 3
    • Start in the middle of the left side and insert a plastic opening tool between the rear panel and the front panel assembly.
    • Carefully run the plastic opening tool along the left and top edge to pry the rear panel away from the rest of the device.
    • Place opening picks along the side you have already pried open to keep the back panel detached from the rest of the device.
    • Be sure to work carefully, as prying too firmly can crack the screen.
  3. Samsung Galaxy Tab 10.1 Rear Panel Replacement: step 3, image 1 of 3 Samsung Galaxy Tab 10.1 Rear Panel Replacement: step 3, image 2 of 3 Samsung Galaxy Tab 10.1 Rear Panel Replacement: step 3, image 3 of 3
    • Using the plastic opening tools, continue to carefully run along the right and bottom edge, and then lift the screen from the back panel.
Davie Sy
1,430 Reputation
4 Guides authored
Cal Poly, Team 13-5, Forte Fall 2013 Member of Cal Poly, Team 13-5, Forte Fall 2013
CPSU-FORTE-F13S13G5
5 Members
17 Guides authored
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 56
All Time: 39,200
