Samsung Galaxy Tab 10.1 Battery Replacement
  1. Samsung Galaxy Tab 10.1 Battery Replacement, Rear Panel: step 1, image 1 of 2 Samsung Galaxy Tab 10.1 Battery Replacement, Rear Panel: step 1, image 2 of 2
    • Place the bottom of the tablet towards you.
    • Remove the 4.1mm screws near the charge port with a Tri-Wing screwdriver.
    • If there are plastic tabs covering these screws, use pointed tweezers to pry the tabs out.
    • On model GT-P7500, this step is omitted, as that model doesn't have these 2 screws.
  2. Samsung Galaxy Tab 10.1 Battery Replacement: step 2, image 1 of 3 Samsung Galaxy Tab 10.1 Battery Replacement: step 2, image 2 of 3 Samsung Galaxy Tab 10.1 Battery Replacement: step 2, image 3 of 3
    • Start in the middle of the left side and insert a plastic opening tool between the rear panel and the front panel assembly.
    • Carefully run the plastic opening tool along the left and top edge to pry the rear panel away from the rest of the device.
    • Place opening picks along the side you have already pried open to keep the back panel detached from the rest of the device.
    • Be sure to work carefully, as prying too firmly can crack the screen.
  3. Samsung Galaxy Tab 10.1 Battery Replacement: step 3, image 1 of 3 Samsung Galaxy Tab 10.1 Battery Replacement: step 3, image 2 of 3 Samsung Galaxy Tab 10.1 Battery Replacement: step 3, image 3 of 3
    • Using the plastic opening tools, continue to carefully run along the right and bottom edge, and then lift the screen from the back panel.
  4. Samsung Galaxy Tab 10.1 Battery Replacement, Battery: step 4, image 1 of 3 Samsung Galaxy Tab 10.1 Battery Replacement, Battery: step 4, image 2 of 3 Samsung Galaxy Tab 10.1 Battery Replacement, Battery: step 4, image 3 of 3
    • Flip up the retaining flaps on the ZIF connectors that secure the three large ribbon cables.
    • Carefully pull the three ribbon cables from their sockets on the motherboard.
  5. Samsung Galaxy Tab 10.1 Battery Replacement: step 5, image 1 of 2 Samsung Galaxy Tab 10.1 Battery Replacement: step 5, image 2 of 2
    • Remove the ten 3 mm Phillips #00 screws surrounding the battery.
  6. Samsung Galaxy Tab 10.1 Battery Replacement: step 6, image 1 of 3 Samsung Galaxy Tab 10.1 Battery Replacement: step 6, image 2 of 3 Samsung Galaxy Tab 10.1 Battery Replacement: step 6, image 3 of 3
    • Lift the edge of the battery up with your finger or a spudger.
    • Detach the battery by holding the motherboard down while gently lifting the battery up.
Jess McCafferty
1,704 Reputation
2 Guides authored
Cal Poly, Team 13-5, Forte Fall 2013 Member of Cal Poly, Team 13-5, Forte Fall 2013
CPSU-FORTE-F13S13G5
5 Members
17 Guides authored
Past 24 Hours: 5
Past 7 Days: 33
Past 30 Days: 167
All Time: 359,918
