Samsung Galaxy S3 Mini Rear Camera Replacement
  1. Samsung Galaxy S3 Mini Rear Camera Replacement, Removing Rear Casing: step 1, image 1 of 3 Samsung Galaxy S3 Mini Rear Camera Replacement, Removing Rear Casing: step 1, image 2 of 3 Samsung Galaxy S3 Mini Rear Camera Replacement, Removing Rear Casing: step 1, image 3 of 3
    • Flip your phone so you are facing the back.
    • Locate the notch at the top and gently use your finger or an opening tool to remove the rear casing.
  2. Samsung Galaxy S3 Mini Rear Camera Replacement, Removing Battery: step 2, image 1 of 2 Samsung Galaxy S3 Mini Rear Camera Replacement, Removing Battery: step 2, image 2 of 2
    • Use your finger or an opening tool to pry the battery out of the phone.
  3. Samsung Galaxy S3 Mini Rear Camera Replacement, Removing Screws: step 3, image 1 of 1
    • Use the Phillips #000 Screwdriver to remove the 10, 4mm screws holding the plastic frame in place.
  4. Samsung Galaxy S3 Mini Rear Camera Replacement: step 4, image 1 of 2 Samsung Galaxy S3 Mini Rear Camera Replacement: step 4, image 2 of 2
    • Using an opening tool, gently separate the plastic framing from the phone.
  5. Samsung Galaxy S3 Mini Rear Camera Replacement, Removing Circuit Board: step 5, image 1 of 3 Samsung Galaxy S3 Mini Rear Camera Replacement, Removing Circuit Board: step 5, image 2 of 3 Samsung Galaxy S3 Mini Rear Camera Replacement, Removing Circuit Board: step 5, image 3 of 3
    Tool used on this step:
    Buy
    • Unhook the two electrical connections at the bottom of the phone using your fingernail or a spudger.
    • Next, use the spudger and tweezers to remove the speaker at the top of the phone.
    • Once the 3 components have detached, the circuit board should release from the phone except for 1 connection on the underside.
    • Detach this connection using the spudger.
  6. Samsung Galaxy S3 Mini Rear Camera Replacement, Removing Camera: step 6, image 1 of 3 Samsung Galaxy S3 Mini Rear Camera Replacement, Removing Camera: step 6, image 2 of 3 Samsung Galaxy S3 Mini Rear Camera Replacement, Removing Camera: step 6, image 3 of 3
    • Flip the holding tab to the open position.
    • Gently, separate the rear camera and the motherboard.
Megan
1,186 Reputation
6 Guides authored
Michigan Tech, Team 1-8, Lauer Fall 2014 Member of Michigan Tech, Team 1-8, Lauer Fall 2014
MTU-LAUER-F14S1G8
3 Members
6 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 1,130
