Introduction
Use this guide to replace a damaged rear glass panel on your Samsung Galaxy S6, or remove it to access other components.
Removing the rear glass destroys the adhesive holding it in place. Follow this guide to reinstall the rear glass.
Heat the iOpener for thirty seconds.
Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
Fill a pot or pan with enough water to fully submerge an iOpener.
Heat the water to a boil. Turn off the heat.
Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
Use tongs to extract the heated iOpener from the hot water.
Thoroughly dry the iOpener with a towel.
Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
Lay the heated iOpener over the rear panel for about two minutes to loosen the adhesive around the edge of the glass.
Shift the iOpener to heat the remaining section of the panel for another two minutes.
Once the rear glass is hot to the touch, apply a suction cup near the bottom edge of the glass.
Lift on the suction cup to create a small gap underneath the rear glass, and insert an opening pick into the gap.
Slide the pick along the bottom edge of the phone to slice through the adhesive securing the rear glass.
Repeat the heating and cutting procedure for the remaining three sides of the phone.
Leave an opening pick under each edge to prevent the adhesive from resealing.
If you're reusing the rear glass, remove any adhesive from it as well.
If you're reinstalling the old rear glass, or using rear glass without adhesive pre-installed, follow this guide.
