Introduction
Removing the rear glass panel from your Galaxy S6 destroys the adhesive holding it in place. Follow this guide to replace the adhesive tape on your Galaxy S6's rear glass. Most adhesive strips will come packaged as shown, although the film dimensions and color may vary.
Before beginning, we recommend you remove any residual adhesive from the glass panel using a q-tip and solvent such as isopropyl alcohol.
Grasp the adhesive from both sides and align the tape over the rear glass.
Lay the adhesive on top of the glass.
If you didn't perfectly align the adhesive with the panel, use an X-Acto knife to trim away the edges.
Use a pair of tweezers to remove any adhesive still on the midframe.
Clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth.
Align the top of the rear glass with the top of the phone.
Press the top edge of the glass into the midframe so that there's no gap at the top.
